I recently started recording tv programs and then i also removed the commercials. Since the show wuz a half hour long, after removing the commercials, the show is approx. 12-15 minutes long. So now, i have the three files for each show, after taking the commericials out. But, when i try to multiplex the three files in TMPGEnc 2.58.44.152 Plus, the first part plays but when the second part is suppose to come on, it just becomes black for the rest of the video. Is there any way i can multiplex these files so that they'll all play continuously? Is there any other program i can use besides TMPGEnc, and is downloadable with a 56k? HELP!!!!
Under MPEG Tools, go to Merge & Cut. Import all of your clips. click Correct to make sure they all match. Then select your output file and RUN.
This should do the trick. If I've explained what you've already done - sorry.
Thanks! Worked Perfectly, i got confused with the multiplex and the merge buttons, and i did not know about the correct thingy. Thanks!
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGEnc plus & ac3
By natty in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 09:01 -
demultiplex and multiplex ..........HELP!
By efiste2 in forum DVD RippingReplies: 1Last Post: 21st Jul 2007, 17:01
