hi,
ive succesfully encoded a divX dvdrip to svcd.
using tmpenc, following the tutorial on this sites to the end.
now the problem is ..... when i play it in cyberlink powerdvd. it plays up perfectly the first 5minutes or so nice graphs etc. then after about 5 minutes the audio just stops, n theres no audio at all..... i havent been able to see if this goes on trough out the whole movie cuz powerdvd doesnt allow me to forward the svcd mpg file , i can only play or stop it.
like i said i followed the guide and also first saved the audio as a wav, using virtualdub and used the extracted wav as an audio source in tmpgenc.
but still i have this audio prob, how can i solve this?
what could be the problem?
thanks in advence
Mid
by the way sorry for the double post.
i tried deleting 1 post but it wasnt allowed
awaiting your reply.
-Mid
<font size=-1>[ This Message was edited by: M1dnight on 2001-08-16 07:36:40 ]</font> -
hmm...how was you able to double post?...it should be impossible...did you do anything special or?
i pressed post and it seem to be not working
so i pressed post again. [i have a slow connection]
but your an admin cant u just del the other post,its identical.
but... i take it you dont have answer to my problem .
oh well
Mid -
but I haved added a check so it should not be posssible to post 2 exact same msgs....hmmmm....have to do some more tests.
To your problem instead:
Are you sure that you select uncompressed wav in virtualdub? The wav file should be about 10MB/minute.
<font size=-1>[ This Message was edited by: Baldrick on 2001-08-16 09:32:31 ]</font> -
Oh i c... well trust me it doesnt work lol.
but yes i selected full processing mode in vdub
wav is about 1 gig
i really cant understand it
it sux, i need the audio -
i feel so silly ,
at the startup it tells me its the demo and it only good for 30min playback
and 5minutes respectively video + audio
sorry
guess it does that on purpose
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
UGH!!!! READ problems again, this time with Sony DVD burner Sata 22x
By Clint Eastwood in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Feb 2009, 01:31 -
Problems with LG GH22LS30 Read speed
By Clint Eastwood in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Dec 2008, 22:50 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17
