I have burnt a VCD, but when I play it on my Samsung SV-DVD1E, the pictures come out in a diagonal line, as though it is not advancing enough pixels before starting to show the next line of the picture. Any ideas?
burn the VCD again at a lower or speed or check to make sure your DVD player can play VCD's. i'm not sure any of this will work but give it a shot
If idiots could fly, vcdhelp.com would be an airport. -
Here is the reviews of you players compatability.
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=569&Search=Search&#comments
If you are new to this.
Don't waste DCR's.
Encode small 5 minute clips on CDRW and test it out on your DVD until you find something that works for you."Today is only yesterdays tomorrow" -
Originally Posted by Baaartman
Did you use a good quality disk ?, was the original source good quality ? DVD rip ? Downloaded CAM ? -
I used VCD easy on my (compatible, according to the list) DVD player to burn JPEGS onto a Verbatim disc at a speed of 2X. Ihave reburnt the disc several times but have had the same problem time and time again, though I have yet to try single speed, perhaps that would be the next step?
JPEG !
Sorry, when you said VCD, I automatically thought you were making a compliant Movie VCD not a slide show !!
Copy subtitle formatting?
By zf1223 in forum SubtitleReplies: 2Last Post: 27th Dec 2009, 22:14 -
Formatting a DVD+RW
By V Bot in forum MediaReplies: 10Last Post: 28th Jul 2009, 14:09 -
klite after formatting
By dogano in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2009, 06:27 -
Formatting a rewriteable DVD?
By c5vetman in forum MediaReplies: 3Last Post: 27th Mar 2008, 02:05 -
DVDR+RW needs formatting?
By lmcnlcy in forum DVD & Blu-ray RecordersReplies: 16Last Post: 11th Jun 2007, 21:07
