I can't explain this... It's really very strange. I converted a DivX to MPEG2. Everything works fine untill i want to cu the movie in parts... It says: Searchin *****.MPG it says that for a very long time untill sudenly it starts producing a Video stream, everything is still normal. It does the same for the Audio stream. But the last second of my audio stream, TMPGenc suddenly hangs... What to do?
try bbmpeg, located here: http://www.vcdhelp.com/tools . then read the guide also on this site in the "Edit" section on how to cut mpeg 2.
If idiots could fly, vcdhelp.com would be an airport. -
I usually find that a more successful method of producing a 2 part MPEG,is to split it during the encode (ie: use the source range and batch encode functions).
"Today is only yesterdays tomorrow" -
Does this happen on the first half, or only the second half ?, if its the second half only try marking the end a few frames back in the source range.Originally Posted by El Torro
You can also try using the same function, but streaming the whole movie incase there is a problem at the end of the file. Make sure MPEG 2 is selected from the drop down list -
Thanks for the replys... But i think it probably has somthing to do with my comp...
I'm gonna see if i can fix it on some sort of magical way...
Oh that's easy, I will ask Merlin to conger up a spell for you.. Zap...**"!** there it should be ok now ?Originally Posted by El Torro
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 22:25 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 10:16 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 09:32 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 19:10 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 22:45
