I have MPEGed an AVI movie with TMPGenc , no problems.
I have transferred the Mpeg file onto a CD with Roxio Platinum, no problem,
When I put it in my JVC 7 discs DVD I just get a menu with the files (MP3) press play, nothing happens.....Am I doing something wrong (probably)?
Can someone help,lease
Ps: If I put the CD on my computer, it plays fine
What exactly do you mean when you say:
If you literally just copied the mpeg to a CD-R, then it won't play in a stand alone player. There is a standard file structure that must be followed. I don't use Roxio (others have had problems), but if it has a 'create VCD' option, then use that. I use Nero and it does have an option to make a standard compliant VCD.I have transferred the Mpeg file onto a CD with Roxio Platinum
Morloc -
Yes my DVD plays all kind of formats including VCD, it says so on the front panel.
Roxio platinum has the VCD option, " create a video cd using your MPEG files" which I used and it does have a structure -
Have you tried playing the VCD in a software player like Power DVD on your PC? Alternatively, have you tried making a test VCD using one of the sample files available on this site? These tests may help to narrow down the source of the problem.
Morloc
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
.SRT Font Size When Playing Using Flashdisk On Stand-alone DVD Player
By randy3101 in forum SubtitleReplies: 5Last Post: 9th Apr 2010, 01:48 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
What stand alone dvd burner is used here by most of you
By 2boot in forum RestorationReplies: 17Last Post: 27th Feb 2008, 21:31 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 17:51
