Hi everyone,
I am a newbie to burning vcds. I got a quick question, I had a DAT file in my hard drive and would like to burn it to a VCD, so I can watch it from my vcd player. I read the AUTHOR section of the "HOW TO" section and I understand how to burn MPG file(s) to VCD. However, do I use the same method to burn DAT file(s) too just like 'MPG --> VCD'? Or do I have to convert DAT ---> MPG, THEN, burn it as VCD? Thanks in advance!
Well nero and ez cd creator will accept a dat file just like an mpg, and it will probably burn fine. I've never had any problems with it but to be safe you should really always convert the dat to mpg first. Use vcdgear (www.vcdgear.org) It only takes maybe 1 min to do the conversion.
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19
