Here's me prob ..... I`m wanting to have a mess around with video capture (dvds, vhs etc) but have hit a snag.
I have installed a wintv go cap card no probs and used the WDM drivers, I hook the dvd player (philips DVD711) up the card using straight thru 5.0mil fem phono connection + the usual two fem to one 3.5mil stereo jack for me audio and then fire up the tv application software...... I can see and hear what i`m wanting to cap on the wintv app no probs (when im using a vcd that is .... my dvd originals play all funny .. i assume this is the macro protection ... anyone know how to get around this?) .. anyway, I can see what i`m wanting to cap ok so i close down the wintv app and then fire up vdub, go to file, capture and then ..... nothing ..... vdub crashes after giving me the message that the cap drivers are already in use by another app.
I`ve tried ctrl+alt+del shutting down the offending app but still it won`t do it for me .... i`m getting really pissed off with this and would love a bit of straight forward english help
Oh and don`t recommend vcdhelp.com coz i`ve been there (thats how I got as far as I have).
Could also do with a bit of help in regards to the macro disabling bit of me player/card?
Any help greatly appreciated
Dylan
vdub doesn't support wdm drivers, only vfw. i had this problem, but found the answer just using the search function on these forums
Hehe ....... something that simple ..... thanks very much.
Teach me to use the search facility in future
Thanks again for the info
Ok.... vfw drivers solved me problem
Now, after using the search facilityOh well, maybe i`ll buy a cheap pc based player and use that to rip em.
Thanks for you help anyhow humdinger .
Dylan
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 20:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
