  1. I have ripped a dvd.using dvd2svcd so far so good.I have read as many rellevant guides as i can.from the movie file I bunrt the muxed mpegs in nero 5.5 good quality.but cannot wind foreward on standalone dvd player so as i understand it i need to burn the cue/bin files to retain the indexes.
    heres my problem i have followed the guide to burning cue/binfiles .If i select burn image file in the pop up window movie files I have to change image files at bottom (nothing shows)to all files .If I then select ,open CD_Image_File_CD1.cue and try to write pc cannot find it . cue file and log shown at bottom.So I tried using daemon tools followed guide copied virtual drive cd1 plays ok in power dvd when copied does not play.so i tried new guide and cdrwin 3.8 cannot find my recorder onscsi or ide bus.One problem i am aware of my pc dvd player is not dma enabled but ok recording at the right speed. What am i doing wrong.
    Thanks for any help in advance.stand alone does support svcd.
    FILE "CD_Image_File_CD1.bin" BINARY
    TRACK 01 MODE2/2352
    FLAGS DCP
    INDEX 01 00:00:00
    TRACK 02 MODE2/2352
    FLAGS DCP
    INDEX 00 00:07:22
    INDEX 01 00:09:22
    INDEX 02 00:09:23
    INDEX 03 04:05:55
    INDEX 04 07:11:39
    INDEX 05 09:22:04
    INDEX 06 12:04:20
    INDEX 07 14:11:55
    INDEX 08 18:36:52
    INDEX 09 23:15:32
    INDEX 10 26:56:10
    INDEX 11 45:44:59
    INDEX 12 49:07:54
    INDEX 13 54:13:13
    INDEX 14 56:58:29
    INDEX 15 63:01:70
    INDEX 16 67:31:38
    INDEX 17 72:09:03
    INDEX 18 76:32:42
    INDEX 19 79:26:00
    This is nero log
    Windows NT 5.1
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00
    ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.28, size=172099 bytes, created 21/05/2001 13:35:20
    Nero Version: 5.5.1.8
    Recorder: <GENERIC CRD-BP1500P> Version: 6z34 - HA 2 TA 0 - 5.5.1.8
    Adapter driver: <atapi> HA 2
    Drive buffer : 2048kB
    CD-ROM: <V386 STEALTH DVD> Version: 1.0h - HA 0 TA 0 - 5.5.1.8
    Adapter driver: <Stlth317> HA 0
    === Scsi-Device-Map ===
    CdRomPeripheral : V386 STEALTH DVD 1.0h Stlth317 Port 0 ID 0 DMA: ?
    DiskPeripheral : MAXTOR 6L040J2 atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : ATAPI DVD-ROM 16X atapi Port 1 ID 1 DMA: Off
    CdRomPeripheral : GENERIC CRD-BP1500P atapi Port 2 ID 0 DMA: Off
    AutoRun : 1
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 61865984 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 511MB (523760kB)
    Free physical memory: 264MB (271100kB)
    Memory in use : 48 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry: 1
    Wizard: Off
    CD-Image
    21.9.2002
    17:17:52 #1 Text 0 File Burncd.cpp, Line 1497
    Recorder: GENERIC CRD-BP1500P;
    CDR code: 00 97 28 26; OSJ entry from: Multi Media Masters && Machinary SA
    ATIP Data:
    Special Info [hex] 1: D0 00 A0, 2: 61 1C 1A (LI 97:28.26), 3: 4F 3B 4A (LO 79:59.74)
    Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
    17:17:52 #2 Text 0 File ThreadedTransferInterface.cpp, Line 800
    Prepare recorder CRD-BP1500P for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x20 Close CD
    Tracks 1 to 2:
    TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 0 352800 1639344
    TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 1639344 1992144 845285280
    17:17:52 #3 Text 0 File ThreadedTransferInterface.cpp, Line 665
    Setup items (after recorder preparation)
    0: TRM_DATA_RAW_MODE2 (ISO9660 Mode2/XA)
    2 indices, index0 (150) not provided
    original CD pos #0 + 547 (547) = #547/0:7.22
    not relocatable, CD pos for caching/writing not required/not required, no patch infos
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 547 blocks [CRD-BP1500P ]
    1: TRM_DATA_RAW_MODE2 (CD-ROM Mode2/XA)
    20 indices, index0 (150) provided
    original CD pos #697 + 1 + 17732 + 13934 + 9790 + 12166 + 9560 + 19872 + 20905 + 16553 + 84649 + 15220 + 22909 + 12391 + 27266 + 20218 + 20815 + 19764 + 13008 + 1790 (358543) = #359240/79:49.65
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 358543 blocks [CRD-BP1500P ]
    17:17:52 #4 Phase 36 File dlgbrnst.cpp, Line 1372
    Start of burnprocess at 8x (1200 KB/s)
    17:17:52 #5 Text 0 File ThreadedTransferInterface.cpp, Line 1836
    Verifying CD position of item 0 (not relocatable, no CD pos, no patch infos, orig at #0): write at #0
    17:17:52 #6 Text 0 File ThreadedTransferInterface.cpp, Line 1836
    Verifying CD position of item 1 (not relocatable, no CD pos, no patch infos, orig at #697): write at #697
    17:17:52 #7 Text 0 File Mmc.cpp, Line 14822
    Set BUFE: BURN-Proof -> ON
    17:17:53 #8 WINPFILE 2 File winpfile.cpp, Line 265
    The system cannot find the file specified.
    17:17:53 #9 WINPFILE 6 File winpfile.cpp, Line 386
    The handle is invalid.
    17:17:53 #10 Text 0 File Reader.cpp, Line 553
    open item failed
    17:17:53 #11 TRANSFER -25 File Reader.cpp, Line 554
    Error reading Data
    17:17:53 #12 Text 0 File ThreadedTransfer.cpp, Line 224
    conversion failed, stopping writers
    17:17:53 #13 Phase 38 File dlgbrnst.cpp, Line 1372
    Burnprocess failed at 8x (1200 KB/s)
    17:17:53 #14 Text 0 File Scsicmd.cpp, Line 371
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    Existing drivers:
    File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 05/06/2002 23:35:26
    File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
  2. If you want to persist in using Nero to burn CUE/BIN images, your version is definitely too old. I suggest that you upgrade to the newest vesion (5.5.9.x).
    The older versions had problems burning CUE/BIN images.
    Alternatives for you include CDRDAO + VCDEasy (as a GUI). Make sure you upgrade/install your ASPI layer with ForceASPI if VCDEasy states that your "ASPI Layer is not valid".
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. thanks for the reply but yesterday was a long day I burnt a succesfuff svcd with chapters from cue /bin files using daemon tools and doing a cd copy of the virtual drive as the guide says.The result is fisrt class quality .The one thing I will have to do now for my next is to include 5.1 surround.
