I've just tried to use a white-label cd to play in my 709, but it will not play. I used VCDEasy to create it but it doesn't recognise the disc. Am I doing something wrong? I'm just gonna try a![]()
cd-rw disc to see if it makes a difference after i've read some of the posts and they suggest using different format of discs.
Any help would be grateful
Thanx guys
Without knowing what player you have ..its hard to respond...
Certain units do dislike certian media, some dont play CDRs at all.
Generally..try to play any VCD on your computer..If you have a DVD drive on your pc...it should play as a VCD....But at least check that all the files are there...there should be a dat file in the folder " MPEGAV" thats roughly the same size as your movie...thats the movie that is played off the VCD. This file can usally be viewed like any movie file with a standard CDROM drive and Windows media player. Check this link for complete list of files that should be there.
http://www.vcdhelp.com/vcd.htm
If it work fine on PC.....its probly the media ....or your standalone player may not support VCD -
You should try a different burning program like nero. For some reason when i burned with vcdeasy they wouldn't play in my dvd player.
sorry, i've got a samsung 709. I've checked the list and it says it does support them. I've just tried it on my pc and using windows media player, it says its playing and i get picture, but stills, no movement. I've lost my dvd software, but i have got a dvd player on my pc. Arrgh, this is really starting to annoy me. I've burnt it to a phillips cd-rw and my player seems like its trying to get it to play, but it still doesn't want to.
Any help, gratefully appreciated
cheers
bev
xxx -
Just checked the Samsung 709 player in the VCDHelp compatibility page and it does support VCD...but most say it does not support CDR or CDRW...Meaning that it probly only plays factory pressed VCD's and that will not play your burnt ones.....Some people reported that it will play a few select brands of CDR...(most will play Princo..which is like a generic store brand from places like curcuit city) Another person posted:
Insert the VCD and the player should start to load the disc. This can take up to a minute - but don't worry, it will recognise it. When it has recognised the disc, press the mode button on the remote and program the tracks in the order you want (you have to do this, because for some reason the player won't play the disc otherwise), once again the player will take up to a minute to start playing, but as I said before, if you wait it will run.
You can always try Burning to a CDRW with Nero ...(so if it don't work...nothing lost but your time)... -
Yeah, I read that one, but it doesnt recognise it at all. Thats what i'm trying now, burning to a cd-rw with Nero. Just have to wait and see, eh?
Thanx for your help
bev
xxx
JVC GR-D850u first time user -- transfer to PC
By mister in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th May 2009, 12:33 -
New user
By Ppeter in forum ffmpegX general discussionReplies: 11Last Post: 21st Mar 2009, 07:16 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 15:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 23:08
