I am using an ATI All-in-Wonder 128 to capture using the ATI supplied software (MMC, etc.) and the audio stinks. Cranking up the volume makes it unintelligible, so I have to leave it way down low. I suspect the problem is that I'm using the sound card built into the system. When I capture, I select the highest available setting: 22K, 16-bit stereo. When I inspect the file information from VirtualDub, it reports back 44K audio. I have no reported problems burning to VCD, but the sound on the TV stinks, as you might expect.
Am I better off with a separate card, or will better audio codecs improve things? Can someone recommend better product?
Here's my situation:
ATI AIW 128 video
Shuttle Spacewalker MB, AK31A
--AC'97 Audio (2.1 compliant)
Athlon 1700+ CPU
256MB Ram
40GB harddrive
Using MMC to capture
that audio on that system isnt to great but are you sure you are not inputing into the mic input ?
22khz sample rate doesnt sound like the highest setting and would make it sound like a phone as the upper limit of the freq of the audio would be 11.8khz ... i would think if that is the highest setting you would be better off to cap in mono at a higher sample rate ...
anyways you can pick up now days a cheap sound card pretty cheap that still is alright audio... -
It's in the line-in. So is the consensus for me to buy a separate, better sound card than what is built into the motherboard?
There are no codecs that would improve this? -
You could buy a Turtle Beach Santa Cruz audio card, but if you are just making VCD's you would be better off to buy a ProVideo PV-231 capture card which does hardware MPEG-1 compression. Both audio and Video are done by the card. These cost about $85. An All in Wonder 128 is getting pretty old I know, I have one.
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 02:45 -
What about audio capture?
By Fryster in forum Capturing and VCRReplies: 3Last Post: 25th Dec 2009, 09:47 -
capture not getting audio
By bbxrider in forum Capturing and VCRReplies: 3Last Post: 7th Aug 2009, 13:00 -
Old PC and want to capture TV audio, etc.
By cantthinkofanickname in forum Capturing and VCRReplies: 1Last Post: 21st May 2008, 13:33 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 12:46
