I have a problem with a dvd rip and audio sync when encoding a svcd mpeg and tmpgenc 2.57.
I ripped the dvd with smart ripper and used dvd2avi then when encoding with tmpgenc the audio on both the film and the extras is out of sync by about a second.
Another dvd rip I have on my hard drives encodes perfectly so I`m wondering if the problem lies with smartripper or dvd2avi.
any help would be great...![]()
Did u seperate the audio and video ? and ensure your encoding the same as the orianal, as in PAL. or NTSC..
its probably neither, just that particular dvd you ripped. ive had two films do that to me, shrek by 1 sec and dont say a word by 27 secs! you can correct this on the source range page in tmpgenc
I had the exact same problem you had with the movie Training Day. I tried ot on two different computers (P-4 2.2 and an XP 2100+) and got the same results on two different dvds. Try this, it worked for me. Use cladDVD to rip and do everything else the same. I have no idea why but I have had much better luck with cladDVD and you can also set it up to frameserve right after the rip, somewhat automating the process.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 17:24 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 14:07 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 14:10
