Hi
I have a ATI TV Wonder card. I used iuVCR to capture video. BUT i cant capture audioI have my audio being fed from the tv card into the "line in" on my sound card, it works with everyother program but wont work with iuVCR. I have set the audio to "line in" in iuVCR and still, no audio is captured. can anyone help pls?
thanks in advance
imy
P.S - I WANT to use iuVCR cuz this is the only software that enables to me capture @ DVD reshehe..
i have this exact same problem (using DC10+ card, under Win XP)
anyone know the solution ? -
Hi!
Check the volume control in winXP and make line in is not muted!
I used to have this same problem, and had to uncheck mute after launching IuVCR! Every time!
Hope this helps -
hi
thanks - good idea, i've seen this happen with other software.
but unfortunately it isn't the case here, as i routinely have the recording properties box open to monitor for changes like this.
everything appears to be set correctly but still no audio.
I have since sucecssfully used something else, called Virtual VCR - this works perfectly!
pls help add audio to 3d bluray
By dauyeuub in forum Blu-ray RippingReplies: 8Last Post: 7th Feb 2015, 04:29 -
Recommend Capture card/stick pls
By jubbely2 in forum Capturing and VCRReplies: 5Last Post: 27th Oct 2010, 13:14 -
iuvcr problems....
By Coluph in forum Capturing and VCRReplies: 8Last Post: 29th Nov 2009, 14:01 -
Sony DVD Arch4, audio problem, pls help
By jazu in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2009, 18:14 -
Capturing In iUVCR
By MosThaTeD in forum Capturing and VCRReplies: 0Last Post: 22nd Dec 2007, 20:15
hehe..
