I have a short video clip I'd like to make into a VCD. The clip is an AVI file. It plays fine in the Windows Media Player.
When I used TMPGEnc to convert it to a compliant MPEG1, it didn't convert the video (it was black).
So, I thought I'd open it in QuickTime to convert it to another format, THEN use TMPGEnc to encode it. But QuickTime won't play the video (it was white).
I then realized it was originally compressed with MPEG4. QuickTime doesn't seem to play this type of codec.
I tried opening it in Premiere 6 and After Effects 4 to reconvert it to a non-MPEG4 movie so it'd open in TMPGEnc, but neither program will play the video.
The only program that'll open and convert is Media Cleaner Pro 5. But that conversion is a long process in that program.
So I ask this: how can I convert this MPEG4 to a VCD-compliant MPEG1 easily?
Thanks.
Hi,
Try to encode the file in Panasonic Encoder.I think it will solve the problem.
Bye -
Right after I posted that original topic, I tried the Panasonic Encoder. It seems to hang at "Initializing...".
I eventually had to end the task, as it stopped responding.
Need MPEG1 encoder
By Xpenguin17 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 5th Oct 2010, 10:16 -
MPEG1-->MPEG4 / Just a nominal question..
By Gew in forum Video ConversionReplies: 3Last Post: 22nd Mar 2009, 10:34 -
H264 to Mpeg1
By Timex in forum Video ConversionReplies: 5Last Post: 5th Dec 2008, 23:00 -
MPEG1 anyone else?
By peterbuilt in forum Newbie / General discussionsReplies: 30Last Post: 11th Feb 2008, 22:31 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 30th Oct 2007, 23:47
