hi guys how di i get pulldown to work
i can get the dos black box up but dont know what to write
the file i need to fix is
death.mpv its located in new folder
i have pulldown from dvd2svcd bundle on my pc its located in program files
could someone please let me know how i use it im going crazy thanks guys
Did you read the readme.txt file that came with pulldown (it's in the same dir as the pulldown.exe program)? Basically
"pulldown source_file.mpv target_file.mpv"
there's not need to use most of the flags (but they are listed in the readme). Question: Are you sure that you need to use pulldown? Take a look at:
http://toolbox.sgi.com/TasteOfDT/documents/video/lurker/fields/fields.html
For an explanination of telecine, 3:2 pulldown, fields, etc. Good luck. -
thanks for ure advice and help but ive got no idea with it i have to use it for this mpv file but im unsure how to run it and what are the exact words need to be written if i say what the file is death.mpv abd pulldown is located in dvd2svcd bundle in program files do i copy and paste pulldown.exe to the folder that has death.mpv? im so sorry but im a quick learner but dos i have no idea thanks
so i get the box up and what are the exact words i need to write ? thanks -
If you go to the tools section on this site , theres a GUI for it that makes it a lot easier to use ,just select input and output boxes and away you go
Is called pulldownBatchFE -
thanks soooooo much surf packer ure a legend uve saved my hair from being pulled out!!!!!!! thanks mate
The simplest way to use it is to just drag and drop your m2v file over the pulldown.exe. When its done delete your old file and your new one will be called pulldown.m2v and be stored at c:\
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 16:53 -
A question about pulldown
By Talayero in forum DVD RippingReplies: 8Last Post: 7th Sep 2007, 12:37 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 06:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 03:25 -
Film Pulldown
By Soapm in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 18th Jun 2007, 12:20
