[b]Just bought a HP200I burner for pc. Tried t burn my first movie and it plays on pc but not in livingroom. Have a GE5803P dvd player in livingroom and site said that it played anything they threw at it. Can someone give me ideas to what I am doing wrong. PLEASE HELP. Also tried to burn on dvd+rw and dvd+r disk with same problem.
Results 1 to 13 of 13
How are you burning your discs? What format are you trying to create: VCD, SVCD, xVCD, etc. You can't just drag and drop a MPEG file on a CDR and have your DVD player read/play it.
What program/template are you using to burn your mpeg files? -
I am using nero5599 to burn with. The movie that I was trying to burn I got of the net. I t was called blade2.dvd.rip . I believe it was in svcd format.
WELCOME to the forum. 8)
I think you need to understand the different formats that videos are in.
Go to the What is section for vcd& svcd and study. There will be a quiz on monday worth 75% of your grade.lol
Also the newbie How to section will be of great help to you.
Good luck, The adventure begins here. The greatest forum and the people who run it.
I know enough to be dangerous!!! -
I burned the movie and it plays well on pc, but will not play on dvd player in livingroom. I have a GE5803P player and site said that it played anything they threw at it, but got nada.
Originally Posted by KPSK
did you unpack (winrar) it and it was a bin/cue file ?
did you burn the bin/cue file as a image in nero (file ->burn image-> *.* file types -> select cue file -> hit go ) ?
and did you burn the above on a cd-r disk? > NOT a dvd disk .. -
tried to burn on dvd+rw and dvd+r disk. I am very new to this as you can tell.
burn the bin cue file on a cd-r with nero as i laid it out above ....
and it should work ok in your dvd player
things like vcd and svcd are (even though source was dvd) meant to be burned on a cd-r disk .. ussually a 700mb disk .
if you download movies off the net - there is also a quality thing ..
things like TS, TC , workprint, screener are all vcd (lower quality) but at times some are marked as svcd (screener svcd) ..
svcd dvd-rip is higher quality and ussually almost same as dvd .. there are also dvd-r conversions done which are really good but huge downloads .
stuff like divx and xvid can not be played on a dvd player (standalone) until there are converted to a svcd, vcd or dvd-r format. the quality can be really good on these also . -
but i would like to burn on dvd+r or dvd+rw disk since I purchased a dvd burner. just want to know how to go about burning that way with nero 5599 or do I need other programs to do it
Wondering if anyone can tell me.Why would it normally take so long to download from an ftp site
Any help appreciated
Originally Posted by mysunfire1952
Some of them have caps on them in order to conserve bandwidth.
but even with DSL ,would it normally take 8 hrs or more to download one movie type
Thanks -
DSL, Cable, T1, T3, fiber...... If the site is capped at lets say at 15kbs, Do the math. It will take a long time. Any FTP sites I have been to usually are capped so I don't use them.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning help
By larzhope04 in forum Authoring (DVD)Replies: 3Last Post: 27th Mar 2008, 21:58 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
