hey m8,
I need some help over here, I have nimo codec packs' installed but still can't play mpeg-1/mpeg-2 files![]()
Results 1 to 11 of 11
here are some propeties of the file...
File Name: boa_-_valenti_(sstv).mpeg
File Format: MPEG-2 Program Stream
Author: Moving Picture Experts Group
Web Site: mpeg.telecomitalialab.com
Content: Video and Audio
Duration: 5 min 12 sec
Video Info: 720 x 480, 29.970 fps
Audio Info: 48000 Hz, 393.2 kbps, stereo
Audio Format: MPEG-1 Layer 2
File Name: boa_-_valenti_(2002-08-31_melodix!_mpeg2).mpg
Duration: 7 min 16 sec
Audio Info: 48000 Hz, 229.4 kbps, stereo
File Name: boa_-_valenti_(utaban_09-05-02_mpeg2).mpg
Duration: 16 min 44 sec
no, i was able to play mpeg2 files on my windows media player, but now... its like NAH!! no suitable decompressor found.
Just glanced through the file info...they all apear to be mpeg2...so you may want to install a software DVD. To play MPEG2/SVCD with Windows Media Player you need a software DVD Player installed or a MPEG2 Codec. I would check the tools section for the player and install that, as most of the mpeg2 codecs cost something. (I dont belive that mpeg2 is in the Nemo pack)
http://www.vcdhelp.com/tools.htm#players
Just read what u wrote above....something that you installed may have overwritten or corrupted the mpeg2 ablity you once had...Install (or reinstall) a player and see if it cures the problem -
oh, so i just have to rip the codec out from powerdvd/windvd and i am able to play mpeg2 files on windows media player?
No just installing the player will provide media player with the proper stuff in the system...
Well....you can try installing the PowerDVD demo.....play a mpeg2 file with Media Player....If it works...then uninstall the PowerDVD...but don't let it delete any shared files....the files that you needed should still be in the one of the windows operating folders...(cause most time installing a window app is like a small explosion.....it speads files everywhere...Its these file you want.)
Try one of the players here:
http://www.vcdhelp.com/tools.htm#players"Today is only yesterdays tomorrow"
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40
