Wich video compression and settings should i choose when framserving from VirtualDub to TMPGEnc go get the best quality?!?
Thx.
Rui Fragoso
use tmpgenc default templates first -- they are very good .... as you go along you might change settings but over all go with the defaults
I assume you mean 'which compression settings of VDub' should you use, and the answer is: 'irrelevant'.
Originally Posted by Quoting from VDub's documentation - Avery Lee
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Compression Settings General
By oc6088 in forum Video ConversionReplies: 13Last Post: 7th Oct 2009, 21:14 -
2875 X 768 px with 3000kbps overhead, wich settings?
By pisosse in forum ffmpegX general discussionReplies: 3Last Post: 8th Jul 2009, 13:57 -
Wich one is the best option?
By thenamelessthing in forum DVD & Blu-ray RecordersReplies: 18Last Post: 25th Aug 2008, 13:21 -
wich format?
By logicmich in forum SubtitleReplies: 0Last Post: 20th Feb 2008, 12:00
