Just got a DVD +r/rw drive and was woundering if I should mess with converting my svcd's to dvds?
If so witch guide should I use and what's the best program>'
Either way thanks a ton in advance for the info!
-Antorz
Only convert to DVD if you have the original files you made the SVCDs with, cuz if you try to reencode it, the quality will drop
Convert to DVD (VOB) Highest Quality converter?
By Mark97213 in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2011, 11:47 -
Convert rmvb to DVD with hight quality on mac
By raf0 in forum ffmpegX general discussionReplies: 7Last Post: 2nd Aug 2009, 07:21 -
Best Quality Method to Convert DVD to AVI
By abazabam in forum DVD RippingReplies: 42Last Post: 20th Dec 2008, 14:39 -
Help on how to convert HDTV to DVD Resolution for the best quality
By Kid Chameleon in forum DVB / IPTVReplies: 62Last Post: 5th Apr 2008, 07:31 -
Best way to convert a low quality WMV to DVD?
By Bix in forum RestorationReplies: 2Last Post: 20th Sep 2007, 20:08
