OK Im converting a 704 x 368 DVD rip. What would be the best setting to make it an 800 MB Mpeg 1 file. In the Bitrate setting it is 1603 and the Audio is 41KHZ 160KB/s Dual channel. VB Buffer settings 48. I want the picture to come out soo good that when I go upclose to the screen I don't see any blocks..Any ideas as to what should I do... and also is there a way to make a non standard Mpeg 2 file....? Priority set to Normal, maybe if I increase it to highest quality it could work..? Gonna try it.. Any suggesstions tell me...NOOOOW !
really have not a clue what you are trying to do .. standard templates in tmpgenc work fine ,,,
are you trying to make a vcd ? well a vcd quality is not going to look like a dvd @ 1605 bit rate ... and that bit rate is not vcd anyway ....
what do you mean a non standard mpeg2 ? for what ?
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 23:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 10:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
