SOLUTION FOUND :
As I suspected, absolutely nothing to do with hardware.
With this solution Windows Media Player 8 will play the DAT files.
Here it is, enjoy :
1. First run regedit and find the branch HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\MCI Extensions
2. Then goto EDIT then NEW then String Value
3. Add a String Value name "dat" (no quote marks) and Value data "MPEGVideo" (again no quote marks)
The beauty with reg file you do NOT need to reboot your system as you did if you edited you win.ini and system.ini in the past with win98 and ME.
Results 1 to 30 of 42
can us stupid people get that in english ? can you draw a map im very dumb..... please?
On Windows XP desktop screen click START ( bottom left o f the screen) , then RUN , then type regedit .
After that, just follow the instructions above.
After step no. 3 , just close the regedit window.
There is no trick . And it works. -
added your tips to our play problems section www.vcdhelp.com/play.htm#playproblem
but I have no problem playing vcds .dat using winxp sp1 using media player 6.4, 8 or beta 9... -
Hi Baldrick,
I am happy to be able to contribute with other users, since it took me a lot of time to find this solution.
You say you don't have problems playing DAT files on Win XP .
But as you can see from the number of Posts on this forum, regarding the same situation, many people do have this problem.
So I think this simple solution will probably help many people out there.
Thank's again. -
Hi guys,
I posted a similar post to antoher thread before I saw the XP playing problem is here. I appologize.
Unfortunately, the registry trick didn't work for me. There is always an "I/O error reading disc" (CD). Maybe our problem lies in a burning application. You can not burn a VCD with any burner, the application must follow the VCD 2.0 standard.
If Win ME can play the disc and XP can't, maybe the answer is that XP complies the standard and won't play non-standard VCDs. Maybe. It's just an idea.
I use WinOnCD and I like to hear from you which application you use for burning. Thank you for any answer.
Ian -
Hi guys,
Despite all of gurus here there was no answer to my polite question. S, I did some research.
And I found some that you can't believe: you must stick to VCD 2.0 standard! Surprising, isn't it? After reading all of the post on vcdhelp.com and after burning dozens od CDs, and after readinga again and again tutorials the some good people posted here I came to conclusion:
1) You (including me, I admit) must read VCD 2.0 standard carefully
2) You must be sure thal all, and I mean all, parameters in TMPGenc are OK (say GOP structure)
3) I use WinOnCD and I know jow to burn CD using that particular program, you must do some investigation if you're using something different. For example, I there is only one track in ISO format, VCD will play. If there are more tacks (as described in one of the tutorials), it won't play.)
So, there is no need for MB drivers update, registry altering or woodoo dancing. Stick to the standard. My VCDs play in Win 98, 2000 and XP Pro without any problem.
Regards,
Ian -
hi!!
I need a quick help!!
I have a laptop, which i can connect to my TV . all works fine ,excellent
quality , .
The issue is that i can only see DIVX format on the TV , .
AVI files!
why i can't see MPG FILES FROM SVCD VERSIONS? .
when i drag the video window, i can see perfect in my computer, but if you move to the TV , it shows nothing but the sound, only you can hear.
damn! it's a serious thing.
i use share desktop with TV output , .
that's why i have to drag the video to the "TV" window.
and other thing is , that with this way , i can't see DIVX in full screen. because it shows full screen in my PRIMARY display which is THE LAPTOP
damn!! i'm screw!!!.
helppppp!!!!
thanks!!
macc.
ps: this is my first post here!! ,so HELLO TO EVERYONE!!.divx svcd vcd dvd mpg avi . damn!!!!
macc - try setting your TV output to clone your desktop rather than extend it. Make sure your video drivers are up to date.
If you need more help, let me know, and respond with you OS version, the type of video chipset you have (or your laptop model if you don't know) and your video driver version if possible. And you might want to start a new topic under the software playing forum to deal with this if this does not help you.
Prospero -
Hi!
i have win xp , in a toshiba satellite 5105-s501 ,
GForce 4 440 Go and it's really new, the last model from Toshiba.
goes recently into market . so , the drivers are the latest. but i dont know how to set "clone" for the tv instead of extend my desktop.....
help!
thanksssss!!divx svcd vcd dvd mpg avi . damn!!!!
Hi,
I'm have some trouble here. I'm running XP Pro and can't get Media Player to play a VCD which I know works in another computer. I've tried the tip- of adding the dat file to the registery but it still won't work- all I get is a message from Media Player which says:
Incorrect function.
Can anyone help!
Thanks!!
Chris. -
When the computer first read the VCD, it did not have any problems. But when i move the slider bar(the tracker, or to move to a certain part of the movie) it stops. I dont remember exactly what happened. Now i cant read this VCD file. I can open the VCD, and get to main file, or the .dat file, but i cant read it. It freezes the computer, until i eject the CD. My other computer did not have problems reading it over and over again. Anyone have any ideas of why this is happening?
hi, I can't load a vcd with windows xp..I try the tip with regedit, Aspicheck, and try with codecs, 5.02, xvid, and old codecs... I always get the same error message... I try with wmp 8 and zoom player.. I know the file works ...
HELP... -
I'm having the same problem as ChrisB. I have no problem playing VCDs on my old laptop with an earlier version of windows, but it won't run on windows XP. I've tried different video players, but the problem is pervasive through them all. I made the change to my registry, but it didn't work for me. Does anybody else have a solution to this problem? I will be forever grateful if somebody knows how to fix this problem.
-Ben -
I never had this problem, just clicked all files on media player and played the dat file.
IVE FOUND A SOLUTION
like many other ppl i have a problem playing .dat files on my computer, i have tried every thing i could think off. the other day i came across a neat little program that will change a .dat to an mpeg, which worked on my computer. if u have the same problem of ur .dat files not working i would suggest downloading the program,
http://www.vcdgear.com/download_gui.html
and simply changing the dat or bin/cue to an mpeg formatt. -
ok i am pretty sure that i followed the steps correctly but i am still having problems all i can see on my vcd are read only files ?
-[SMW]-proToType<|X|> 4 1337 /\/\0f0 -
With all the problems people are having with WMP, may I suggest that you try using a software DVD player to play VCDs (e.g., WinDVD or PowerDVD). It works better, you get to see menus AND they understand the concept of display aspect ratio.
Regards.Michael Tam
w: Morsels of Evidence -
CAN ANYONE PLEASE HELP A FRUSTRATED xp USER!!!!!!!!!!!! How do you run DivX or WM movies on full screen without it constantly on catch up??????????? (But when it run in small format it plays lovely. I Have just upgraded to XP from W2k and it was PERFECT on W2K.
Any Suggestion would be greatly appreciated.
P.s What the best P2P file share to use. As i want to share my latest releases with ya all. Just out in the cinema -
Dont run ANY other programs when you are running full screen. Also try defragging your disk. Add more memeory. Get a faster processor. Make sure you have at least 500mb free on your system disk (normally C
. Try winDvd or PowerDvd rather than WMP6 or WMP8.
DinoPollardGuest
I've tried Lula1's solution, but VCDs still won't play in Windows Media Player. It always comes up with a box that says "Incorrect Function."
I could not play VCD movies on my Windows XP system. After trying this simple registry entry I have not had a problem playing VCD movies on XP.
DinoPollardGuest
I have XP and I did try the registry solution and VCDs still don't play on my computer
Does anyone have any tips or suggestions? -
Try using isobuster from Smart Projects (isobuster.com). Just point to the Dat file when it reads the VCD and extract the user data as an MPG to your hard drive. Works everytime for me!
Synchron 8) -
Well, if you extract the mpeg off a VCD, of course you can view it... However, that hardly seems like a good solution for someone who just wants to view the VCD on their PC...
Regards.Michael Tam
Surely I must be missing the point here - BUT if you simply open media player in XP, go to files and explore the cd and select the DAT files they open and play. Even if the CD contains many .dat files they are listed.
Also Powerdvd plays VCDs just fine.
Opening movies full screen - well I suppose it all depends on processor, graphics card, chipset drivers, original size of the movie, what else is running in the background hogging resources.TOMMO
Windows Movie Maker 6 - Problems with playing timeline
By leegutcher in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2013, 13:16 -
Playing titles via Windows instead of a player
By JustSteve in forum Blu-ray RippingReplies: 2Last Post: 31st Jan 2012, 07:23 -
Playing PC games with Windows Vista?
By Bob W in forum ComputerReplies: 7Last Post: 16th Sep 2008, 22:13 -
Playing Captured Video in Windows
By Conroe in forum Newbie / General discussionsReplies: 11Last Post: 15th Aug 2008, 16:57 -
windows mp is not playing sound on videos (but only on one windows account)
By lightsout85 in forum Software PlayingReplies: 0Last Post: 30th Jul 2007, 15:19
