Is it still 74 mins or does it decrease? Sorry if this sounds stupid but I am a newbie.
Cheers
Zed
Ok On a SVCD it uses twice time as a regular VCD so with my experince using 80min. CD's you can put 38min. and 30 seconds, without overburning, I have put upto 40min. and 30 seconds with using overburing turned on at 81min. 45 seconds using NERO 5.5.
Also did you know that on SVCD it has 4 - 2 channel audio tracks you can use, I have not figured how to use the other 3 yet. -
You can fit anything from 35 minutes and up to say 100 minutes/CD. It's all depending on the video and audio bitrate you choose. Less minutes/CD means of course better quality.
About up to 50-60 minutes/CD is an acceptable quality. But it depends on lots of stuff as what encoder, how to source is and so.
<font size=-1>[ This Message was edited by: Baldrick on 2001-08-16 04:13:53 ]</font> -
Does that mean that you're really looking at 3 CDs to get a standard sized film on to SVCD format?
Alan -
Thanks for the replies guys its all starting to make sense to me now
cheers
Zed -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You could probably fit a standard length film on 2 CDs (esp. if you use 80min media) and still have acceptable quality.
You probably don't need to venture into 3 CDs until your film is over 2 hours long.
Regards.
Michael Tam
w: Morsels of Evidence
streaming video stored on one pc to my local network
By cougs_83 in forum Video Streaming DownloadingReplies: 19Last Post: 6th Sep 2011, 10:03 -
Need to cut out 5 minutes of video from a dvd
By darkcyber in forum EditingReplies: 5Last Post: 2nd Nov 2010, 18:10 -
Last few minutes of video frozen...
By JohnC1726 in forum RestorationReplies: 3Last Post: 14th Jan 2010, 08:56 -
video file out of sync after 20 minutes
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2009, 04:21 -
Video crashes after a few minutes
By Diego123 in forum Software PlayingReplies: 16Last Post: 4th Jan 2008, 10:04
