when i play a vcd on my dvd player that i burned some play the video slow but the audio is fine .has it to do with the encoding ?.Also which template do i use for which frame rate.29.97, 25, 23.976 which template is right for which frame rate .I also have some movies that have a framerate of 14.985 (29.97 interally) what does that mean?.I useally use the PAL template cos i live in the uk but my tv and dvd player can play
NTSC .I use TMPGENC to encode thanks for any help.
mado21![]()
When you load a template, TMPGEnc lists the spec at the bottom of its screen, it shows fps.
There are times when a conversion can give jerky playbacks, on screen pan's moving left right fast etc, depending on your DVD/TV how bad they will be.
I use the PAL VCD template for "Everything"
and 90% of the time they are very good, and those other 10% only have missing frames on screen pans, but they are not that bad.
With a good quality source the conversions will be very good, but cam movies and the like are pretty awful
slow HD playback even though i have an okay PC (pic)
By edgeofthecosmos in forum DVB / IPTVReplies: 28Last Post: 30th Jul 2011, 21:17 -
Very slow playback software
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 16:30 -
Slow AVI playback?
By JeffM in forum ProgrammingReplies: 10Last Post: 24th Apr 2009, 07:44 -
Slow playback on HD MP4 video
By excelsion in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2009, 00:22 -
Slow MKV 1080p Playback!
By The_WRATH in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 14:50
