why should i not use nero (with plug in) to encode to SVCD
I am reading that TMPGe is the way to go but I need to buy something to encode DivX to SVCD?
TMPG is much better than TMPGenc for encoding SVCD's.
You can burn SVCD's with VCDeasy. -
thanks, I got that much, but is it a quality issue? or speed, or are there more options / flexibility, etc...
correct me if I'm wrong, but isn't TMPG and TMPGEnc both the same programs?Originally Posted by snowmoon
later,
alirio -
Yep... type... supposed to be NERO...
And to answer the last question...
YES TMPGenc has better quality and speed ( except two pass VBR where the quality is even better but takes longer ). Tmpgenc wins in options and flexability too. -
Thanks, I will download it now. The latest version is 2.58. Will this convert my DivX avi files to SVCD assuming I follow the guides on this page?
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 20:51 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10
