  1. I had Transformers: The Movie in dvix format well over 800MB so in order for me to save it to 2 cd-r's I cut the movie with Vdub, I think that was the program I used.
    Now that I tried joining it with VDub I ended with an 800MB file and only half of the video length...huh? What am I doing wrong?
    What is the best joining program for avi files?
    later,
    alirio
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    Cutting or joining AVI's .... VirtualDub is usally good and easy (I'm surprised you had a problem with it) I would definatly give it another shot.
    Heres a how to on it...see if you missed anything.. http://www.vcdhelp.com/virtualdubedit.htm
  3. I definitely give it a try once again when I get home tonight, I'm at work right now so I'm trying to post any of my questions I usually encounter.
    A rookie like myself is new to all this and I'm having fun encoding and all thats involved.
    I'll let ya know hopefully by tonight the outcome, thanks again.
    later,
    alirio
  4. yo MaDmiZe,
    I tried again and I don't know what I did wrong the first time, but it worked like a charm.
    Thanks dude for the tip!
    later,
    alirio
