I've noticed that when I play a DVD-R in my DVD players they vibrate. I'm guessing it's the motor. This does not happen when I play a normal DVD. You can feel the player vibrating if you place your hand on top of the player cabinet. Could this damage the DVD player? has anyone else noticed this?
I've played quite a few DVD-Rs in my two set-top players and in 3 DVD drives. I never noticed any unusual vibrations. It could be you have a bad batch of discs that are slightly unbalanced. Some vibration is normal, but if the player is 'walking' like an overloaded washing machine- then you have a problem. :P
If discs are way out of balance, it could strain the DVD player mechanism or strike the lens or other part.
What kind of DVD player do you have? I have a Pioneer 343 which sometimes is noisier and marginally more 'rumbly' then my older Panasonic which is extremely quiet. I think it's more the motor and construction than an unbalanced disc.
Do you have paper-labels on the DVDs in question? That can cause balancing problems. -
i have the same problem in my audiovox from target that i got.... my dvd-r dont have any trbls in any of my other dvd players but when i play it in the portable it doesnt vibrate per say but just makes this crying or kinds sreaching noice.... and it only does it on dvd-rs...... not dvd's..... but it wll stilll play..... i have tried it with verbatium, optodisk and pioneer and it does the same thing wit all 3..... i burn with primodvd and even when i was a novice and burnt wit nero (NEVER AGAIN) it did the same thing.... even when moviefactory burn a dvd it does it.......... WHATS GOING ON
The sound you are hearing is likely a result of a misread. The data stream buffer detects an uncorrectable sequence and forces a speed change,
ranging the laser back to track 0 to get sync and then returning it too
the offending portion of your DVD disc. It sounds alot worse than it
really is and unless it is doing this for several minutes I can't see how
it would cause significant problems with the spindle. -
yea.... it last thru most of the movie.... i havent watch a whole movie yet wit a burn dvd...... but u said " The data stream buffer detects an uncorrectable sequence and forces a speed change,
the offending portion of your DVD disc "
is this something that has to be wit my conversion processes and would do i need to change for it to work???? -
mol3000,
I honestly don't know. You could be right but it could also be to do with
the laser and reflectivity of the dvd-r, or perhaps a firmware problem
that can be fixed via a loader upgrade. For whatever reason, the DVD rom mechanism is having difficulty reading your disc. -
is dvds like cds where the color of the bottom has a little to do wit it.... i use optodisk for the most part which have a purplish bottom...... also how would i upgrade y firmware on my portable audiovox ???????
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Pana E55 vibrates when recording DVD-RAMs
By johnsees in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Sep 2009, 00:58 -
Replacing my HD-DVD player with Upscaling DVD player
By Tacoboy in forum DVD & Blu-ray PlayersReplies: 23Last Post: 21st May 2009, 03:07 -
help,, for burning a dvd movie and player at sony dvd player.
By flowerhorn in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2008, 09:12 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59
