I have a Matrox marvel g200/tv capture card. I'm having the devil of a time capturing using virtual dub. Has someone using this card, or the g400 had sucess? If so, what settings are you using?
Using the Matrox Matrox PC-VCR Remote, I get a very good capture. But I then have to process the resulting mpjeg/AVI through Vdub to get it into TMPGEn for encoding. I would like to be able to capture directly using Vdub.
I'm also making an assumption here..... If I'm capturing (using Vdub) using the Matrox Vidcap driver, Is this still using the hardware compression of the video board, or does this use software compression and muck with the video quality?
I threw my Matrox Rainbowrunner away in frustration a long time ago, but the if you go to matroxusers.com you'll find lots of people that can help you with matrox gear in the dekstop video forum.
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 20:06 -
Problems capturing HDMI with AVerTV CaptureHD/-H727 and VDub
By Gwar in forum Capturing and VCRReplies: 5Last Post: 12th Sep 2011, 20:00 -
Capturing with VDub sometimes doesn't capture audio
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Feb 2010, 21:50 -
TV capturing n Rippin using VduB
By SMChoice in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2009, 11:39 -
Need help in choosing a video capturing card - Matrox
By avinash.rao in forum Capturing and VCRReplies: 0Last Post: 1st Aug 2008, 08:49
