  1. I am having problems buring I-Author cif images using Easy CD Creator 5. It just stopped at about 95% burning. I have read other posts suggesting using Easy CD Creator v4. But version 4 does not support my burner. Any suggestions?
  2. Member adam's Avatar
    Sep 2000
    Well Ez Cd creator is the only program that can burn cif files but you can use the latest beta version of CDMage to convert the cif to bin and cue. With a bin file you'll have lots more burning programs to choose from. You can find a link to CDMage's page in the tools section but make sure to get the beta version.
  3. Member tlegion's Avatar
    May 2001
    Sol System
    Adaptec/Obnoxio EZCD 4 seems to have a million updates. It is now up to 4.05 (but there are intermediate updates that have to be applied). It is here: http://www.roxio.com/en/support/ecdc/ecdcupdates.jhtml
    EZCD v4 guide: http://www.roxio.com/en/support/ecdc/installecdc4.html
    Recorder Database starts here: http://www.roxio.com/en/jhtml/cdrdatabase/database.jhtml
    Heaven help you if you have a Dell: http://support.dell.com/us/en/filelib/download/index.asp?fileid=R29396
  4. Banned
    Jun 2001
    UK
    Why not use a ISO buster, then you can unpack the ISO (Any type) onto your hard drive.
    http://users.pandora.be/smart.projects/start2.htm
  5. Member adam's Avatar
    Sep 2000
    ISO buster will not work on I-Author created cif images. Nor will any other image extractor except for the latest beta version of CDMage.
