Hello, i encoded a file named a knights tale which is a dvd rip when i play the mpeg format it has no sound but the avi file does why is this am i doing something wrong please help as i need to format my pc for windows xpthanks
daz
So let me get this straight. you ripped the dvd to vob files? and then got the avi file how? dvd2avi? and then convert to mpeg1 w/ tmpgenc?
with your computer specs i dont see how you do this? it would take all day and your HD is pretty small.
What guide are you using? -
I guess you downloaded the AVI ?Originally Posted by dazza193
That’s a great movie, hope you get it sorted.
When you convert the AVI in TMPGEnc, just try a little at a time (Click stop) make sure your output is working correctly. You don’t want to spend all that time for nothing.
Make sure you have the audio codec's, load the AVI into Vdub and select file > file properties
Then check what codec's you have Audio > full processing mode > compression Is the codec there?
In TMPGEnc
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
Any use ? -
cheers king john :d me sorted it now oh plus i have a new comp now 1200mhz 512mb ram plus a 60gig HD that goes out to SLBOSS926 i did download the avi of kazaa lite
thanks. -
:d wkd man loved it worth the try in encoding it cheers man cyas later!
Well congrats on the new system i too was in the dark ages until about 2 months ago. i had a 366mhz w/ a 3 gb hd and 96 ram hahaha.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
thanks
