Hi all!
I am new to all of this stuff. I am in need of some pointers. I have a vid that I captured with my Matrox RT2500 in mpeg 2. I need to know how to covert it to Divx for compression purposes.
The video I have shot is around 5 gigs and I need it to fit on one cd. From what I understand about Divx is that it is possible to get the compression that I am looking for from it.
Can anyone advise me?![]()
On the left of this page is the CONVERT link. Scroll down to Convier to DivX and select DVD2AVI guide. You will have to adjust as necessary since this guide presumes that you are going to have to rip the mpg off the DVD first, but you can skip that step.
THANK YOU SOOO MUCH!
I just want to be clear - is it this one that I need:
How to convert to DivX/AVI with DVD2AVI...
Doom9s guides. SVCD to DivX/AVI. Freeware
Thanks again! -
Yes, but like I said you will have to adjust the guide to suit your needs as DVD's need to be ripped you don't need to do that. Other items in the guide may need to be modified as appropriate, it should be fairly clear on what need to change.
DVD (MPEG2) or DivX
By MI6 in forum Video ConversionReplies: 1Last Post: 20th Sep 2010, 14:51 -
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 12:52 -
cannot covert .ts file to anything
By vespera in forum ffmpegX general discussionReplies: 4Last Post: 29th Jul 2009, 01:05 -
Covert 4:3 DVD to 16:9
By phowe in forum Video ConversionReplies: 2Last Post: 8th Jan 2009, 16:26 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01
