what does a higher bitrate do to a movie quality? the higher the better?
thanks!
tvandang
MPEG compression is ~30-70:1 compression. The more bitrate the less compression needs to be applied to the movie. The less compress the more like the source the encoding can be.
But, as many have found, often your TV ends up being the limiting factor in how much of a diffrence you can see. -
so the more bitrate the less compression and therefore you have a bigger size movie? so does it enhance the quality of the movie at all?
thanks!tvandang -
Also remeber that VCD has a strict bitrate specification and SVCD has a MAX bitrate limitation. If you break these specs you cannot guarentee that DVD player will accept them.
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 01:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 23:03
