i use Roxio VideoWave Movie Creator to make VCDs from my camcorder
now i capture with virtualdub en make .mpg with TMPGEnc if that is done i use alle the clips in the program and it works just fine
when i have done in story-maker i must render the movie if that is done i got a .mpg ready to burn but when i burn it to cd and play it on the DVD-player i have to put volume to max to hear somthing and if i open the file on the pc i have normal sound! also if i whant to do somthing with the .mpg in TMPGEnc it say "ilegal MPEG video stream"! and Nero acsept it as a valid .mpg for VCD
but that is not the problem i just want to pump up the volume...
Results 1 to 1 of 1
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 07:02 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
Low sound in rear speakers.
By madman1987 in forum AudioReplies: 5Last Post: 24th Nov 2008, 12:44 -
low sound after burning to dvd
By ymurf in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 14:59 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44
