I recently hacked my Magnovox 450 to be region free, but all I get is a black & White picture where the framing is off (the bottom 1/8 of the image is cut off and restored to the TOP of the TV screen, much like a misaligned 16mm projector image). I assume its a PAL/NTSC problem, but is there more I can do to fix the image?
Greetings,
Have you changed your TV type to be NTSC from multi ? The hack only allows multiple regions to be played. You still have to tell the DVD player to convert from PAL to NTSC. I suspect it's putting PAL out at the moment.
Cheers,
Tony
Toshiba D-VR7 vs. Panasonic DMR-EZ48 vs. Magnovox RZV427MG9
By sturedman in forum DVD & Blu-ray RecordersReplies: 9Last Post: 17th Nov 2011, 00:40 -
OPPO DV-981HD No Longer Plays PAL Discs
By elling in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Sep 2010, 18:38 -
avchd discs plays at 480p on ps3
By sitlet in forum Authoring (Blu-ray)Replies: 0Last Post: 30th Jan 2010, 22:49 -
Hiteker HPD 710 portable plays FS discs Wide screen. Help!
By richco in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Apr 2009, 17:15 -
JVC player suddenly plays only some discs. | Error Codes ?
By Seeker47 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2009, 12:59
