  1. I have been trying to transfer several VCD's to DVD using DVDit PE. I set the audio to DD so not to take up extra space with PCM, but DVDit PE seems to calculate the estimated size of the project using PCM and not DD. So it will not let me burn several VCD's (more than 4) to a DVD because it says there is not enough room. Is there a fix for this. I would like to put more VCD's on the Disk if I could
    Thanks a lot
  2. You can use the custom length to override the default sizes. My version is fussy about the format, i.e. 1.0Gb using the dot and case sensitive.
    darren404
