  1. Hi Folks
    I have a problem if it has been asked before please direct me to the thread. I have an avi file that encodes to mpeg for vcd burn no problem but with no sound output using Tempeng 2.5. The original avi did not play sound. I downloaded Nimo 5.0 codec pack and the avi played the sound. When I attempted to run Tempeng 2.5 to re-encode the avi an error occured saying the avi was unsupported. Infact every avi I try to convert to vcd comes up with the same error. When I did a system restore in winxp I was back to square one. Avi no sound Tempeng ok.
    By the way only the odd avi is affected with the no sound problem.
    Your help you ever you's are would be greatly appreciated.
    Thanks.
    Malcolm.
  2. Banned
    Jun 2001
    UK
    See if this helps
    Select options > environmental settings
    click the VFAPI plug-in tab
    right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
    Installing Nimo, could overwrite existing codec's of different types, DivX 5.02 in Nimo also has spywear.
    Open the AVI in Vdub and select file > file information
    See if you get unknown on anything, or if you see the codec's, take a look to see if you have them installed.
    Quite a lot of people have had problems with Nimo and DivX 3.11 Alpha (And DivX Audio)
  3. Thanks for the info King John, but you mentioned Vdub. My problem is with Tempeng. But I'll have a look and give you the feedback.
    Thanks foir your time.
    Malcolm
  4. Banned
    Jun 2001
    UK
    The settings above was for TMPGEnc, Vdub is used to check the AVI before you use TMPGEnc
    TMPGEnc
  5. You are the King, works superb. I also downloaded the VFAPI plug in from the TempEng site.
    A million thanks for your expert tip.
    I owe you one.
    Malcolm.
  6. Banned
    Jun 2001
    UK
    Good to hear you got it sorted, glad I was able to help in some small way.
