is it possible to decompress an avi(audio and video)then recompress it using a different codec without loseing any quality,so i can convert it? currently i cannot convert it because of the "mmx state" error i vdub. masking bad frames has not worked.
thanks
You wouldn't technically decompress it, it would be more like transcoding directly from one codec to another.
Just open the file in VirtulDub, and select the compression setting to change the codec, and then do a FILE | SAVE AVI. If you have a bad frame, you may have to cut it out using the range tools in vdub, and re-join the two good parts using the APPEND AVI SEGMENT in VDub.
Avoid recompress in DVD Architect
By arcorob in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Apr 2017, 16:59 -
How To Recompress .FLV Video Files
By TonySan in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 17:00 -
Capture DV stream and recompress to XVID on the fly
By a1s2d3f4 in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 18:28 -
DVDArchitect 5.x, how to get video into it and not need a recompress?
By markm75 in forum Authoring (Blu-ray)Replies: 2Last Post: 29th Aug 2008, 10:50 -
fast recompress in avidemux?
By Holonet in forum LinuxReplies: 1Last Post: 28th Jan 2008, 10:16
