  1. Hi,
    when I convert a DIVX to VCD with TMPGEnc, the program crashes after hours, before its at the end. I have Win ME and the latest TMPGEnc-Version.
    ++THX++
    Blackland
  2. Does your PC also crash when you leave it running for hours with other software then TMPGEnc? IT might be a configuration problem not related to TMPGEnc.
    You can also try a different TMPGEnc version or DivX codecs.
    Regards,
    Willem
  3. No, only with TMPGEnc.
    Blackland
