Hi
I tried to convert a ntsc vcd to pal vcd.
The 45 sec. file seemed to be working and was not out of synchronization, but the picture quality got bader. I just loaded the source into tmpeg, selected the new fps and started encoding.
Is there a way to do the same without to loose the picture quality?
thx
Unfortunately, any time you re-encode, your going to lose picture quality. Just make sure your using the best quality settings in TMPGenc to minimize the quality loss.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
