Will it work if I set up TMPGen to save to converted Mpeg directly to the CDR drive rather than the hard drive?
Drink Beer - It's good for you
saving it as a data file you mean !, well it should, but in practice it would probable not
try it out with a CDR-W are you using direct CD or something ? I think that needs the file to be copied, have you run out of room ?
MattyVii,
Depending on the file size your writing to the disc and the time it takes to convert thru TMPGEnc you'd more than likely burn up the drive long before it finished. Just think of it this way, the whole time it's writing to the disc the laser diode is going to be active and generating more and more heat. I don't think it's possible to maintain a sustained burn like that without burning up the diode. You can try it, but don't say you weren't warned.Warning! I'm baaaaaaaaack
Direct transfer
By Jomapil in forum ComputerReplies: 3Last Post: 1st Nov 2009, 12:45 -
Direct x
By hamilton accie in forum ComputerReplies: 2Last Post: 6th Aug 2009, 06:04 -
Direct to External HD
By Galahad in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 20th Jun 2008, 06:11 -
Hard drive camcorder direct to DVD burner?
By h08 in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Oct 2007, 18:47 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 12:37
