I have downloaded a corrupted avi file. I tried to use avidefreezer program to fix the file after I found out the corrupted frame number using virtualdub. I got the avidefreezer program to run, however, it generates an extremely huge file that I had to stop the program before it finished as I was running out of disk space. The original avi file I downloaded is around 600 Meg in size, however, the avidefreezer program generates a file bigger than 2.9 G in size. Does anyone know why?
Thanks very much.
If you have successfully found the junk frames in Vdub, why not just save out another copy to remove them.
Vdub > scan video stream for errors
Video > direct stream copy
Audio > direct stream copy
SAVE AVI (Movie2.AVI)
This saves another copy without the junk frames...
See also my post of Vdub MP3 and junk frames.
To answer your question, the program your using is decompressing the AVI and saving it out uncompressed.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
