Just a newbies question, but i do would like to know whats the difference? I mean if i encode an .avi file to vcd or svcd is there any difference? tenks!!!
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Super Video-CD PAL (MPEG-2 480x576 25fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
Super Video-CD NTSC (MPEG-2 480x480 29.97fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
VCD Mpeg 1, SVCD Mpeg 2
If the AVI is a DVD rip "High quality" you may prefer to make it into a SVCD (If your DVD player will play them) if the AVI is low quality, you might as well make it into a VCD -
please use the search function, for example this may give you some answers http://www.vcdhelp.com/forum/viewtopic.php?t=111938&highlight=vcd+svcd+difference
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 16:44 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Divx or xvid? Whats the difference?
By szalaikornel in forum Video ConversionReplies: 3Last Post: 17th Jan 2009, 13:16 -
Difference between VCD and DVD?
By brandon334 in forum Newbie / General discussionsReplies: 6Last Post: 25th Apr 2008, 11:30 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 00:15
