alright, i just got my capture card working so i could record home videos onto my computer and make small movies. i just made a simple 3 minute flick with one transition effect and then saved it. i used dvd quality capturing at setup. when i opened nero and selected svcd and tried to burn what i'd just made, it said i need a special mpeg2 codec plugin. is this because i choose dvd quality capturing? should i choose mpeg 1 next time?... but if i do, isn't the quality going to be lower? thanks for any advice, peace![]()
I had the same problem - i am using Pinnacle DV Plus card
Can l use MPEG2 format to encode and then burn it with Nero? -
svcd is mpeg 2
i have no probs recording with dallze & burning with nero
the low quality comes from bitrate / size not format
my capture card is a AVerMedia 1394 card. i'm using Video Studio 5.0 to capture with... so where are the options to change bitrate and size? all i've seen are the preset options. what would you say is the best format, bitrate, and size for burning svcd with nero? also, should i download the tmpgenc prog? i've read a couple of post about it, but have no idea what it is and what it does. thanks for the help, peace
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 20:07 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
