I'm encoding my home video with TMpgenc and Author and Burn it using Ulead DVD Workshop. My DVD burnner is Pioneer A04 (I'm not sure what region it is, but definately not region free). My question is, those DVD-R that I burn will it force to follow the region setting in my DVD burnner? or Is under my own control setting in the authoring software?
The DVD-r(w) disks burnt in a Pioneer A04 do not have any region coding on them. I believe that this burner will not (or cannot) write to the part of the disc that contains the regional coding info. All discs burnt on the Pioneer A04 are region free.
The region coding on the drive is only to limit its ability to playback commercial DVD's, just like a set-top player.
Hope this helps. -
:P Thank you very much bugster!!
I suspect the same thing, but I really need someone can confirm that.
Philips DVP3560 - region code hack question
By Malsperanza in forum DVD & Blu-ray PlayersReplies: 7Last Post: 5th Nov 2011, 12:15 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 14:44 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
Sony RDR HX 725 Region Code Hack question
By bootymeister in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Aug 2007, 11:20
