  1. Ok no laughing guys....I'd like to be able to do DVD to VCD on this
    old Pentium Pro 233mhz machine. I've got all the time it needs(yes i'd like a faster machine but has to wait)
    lots of good guides on here and Smart ripper works fine. The problem is it seems all the next step programs require a machine with MMX....FlaskMPEG the older version seemed to be working and doing an encode using BBmpeg i think it's called but it wouldn't play with Windows media player nor my DVD player software that will play mpeg files normally. Help! Is this just impossible? thanks... Schwinn
  2. I think the 'smart rip-dvd2avi-tmpgenc' is the best way to go. try that and see what you come up with. also, how much hard drive space do you have free?
  3. I get the illegal action message that Microsoft is so fond of using for every thing that goes wrong. I jsut tried a fresh installed copy. Same as before no go. I for some reason think/thought this and everything I've tried needs a mmx cpu! Am I wrong?
  4. That URL for quick reference:
    http://www.vcdhelp.com/dvdtovcd.htm
    May be bro, try turning off all MMX stuff in TMPGEnc and see if it runs. Will be slooooow, but you already expect that, right?
    Good luck!
    <hr>
    Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
    <hr>
  5. Thanks for replying. Smartrippper works fine!
    TMPGEnc & panasonic encoders both work fine apox 12 hours to make a VCD could be worst!
    The part i'm, missing is DVD to something the encoders can use! They all seem to need MMX....
