I recently downloaded a SVCD of Resident Evil and when I downloaded it, it was in bin/cue format. I burned it using fireburner then I went to test it on my dvd player in front room. It loads it and all but it doesnt play. I also noticed that when I use WinDVD4 on my comp, it doesnt auto-start like all my other ones that I have burned. I was wondering if anyone can help me fix this because I really want to finish watching this movie on my large TV in front room. Thankies!![]()
It sounds to me like the SVCD Image you downloaded was either created improperly or has somehow become corrupted. What I would do is extract the video files and data you need from the SVCD either manually or by using a seperate program that has this capability, then create a new SVCD before burning it yourself like you have done in the past. There are good guides on this website dealing with repairing VCDs and SVCDs that should help you do this. I would pick through these guides and come up with whatever sounds easiest or best to you depending on the software you are familiar with.
Hope this helps,
Prospero
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 12:01 -
laptop vga port wont work on my moniter
By kingnat2 in forum ComputerReplies: 2Last Post: 12th Jul 2008, 17:47 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 14:41 -
VOB2MPG 0 Vob Sets Problem - wont work
By meno in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Oct 2007, 21:36
