  1. What is MFC42.DLL? I have a web cam that I haven't used for awhile which worked before I downloaded a bunch of tools from this site. I tried using the web cam and it tells me that Snapshot has caused MFC42.DLL and that it will close down. I have a Intel Deluxe Cam and I am using it on OS ME. I tried looking on Intel's site but no such luck and I hope somebody here can help me.
  2. from memory its a library that helps with the registering of DLLS.
    it causes some problems if you have the wrong version or older versions installed. have a look on your intel cams install program, if it has a cab file in there open it and then copy this file to where it should go c:\winnt\system32
    mic
    God created man and finding him not sufficiently alone, gave him a companion to make him feel his solitude more keenly. -- P. Valery
  3. A bird in the hand is worth a foot in the tush-Kelly Bundy
