O.K This will be amusing l'm sure to most but trust me l've had many sleepless nights now! l am trying to encode using TMPGenc for an eventually burn (using the DVD PAL template etc). The stages l have gone from are as follows, l have used Smartripper to rip the movie which has worked ok. I then have used DVD2AVI to create my wav file and movie file which seems to works. My question and worry is within the TMPGenc settings l have basically followed the format which is given in smartripper after the rip, for example Video type =PAL frame size=interlaced Aspect ratio=4:3 frame rate 25fps. These settings l have inputted into TMPGenc using the highest quality encoding rates also. The part which l am not sure about is Bitrate values, now l have used the information smartripper gave me about the bitrates of the movie which were for example Values= average bitrates(3151) the max bitrates= 2516 and the min bitrates=1145 l used these settings within TMPGenc for it's process of encoding also using the 2passvbr setting. Would this be correct or am l way off the mark with what l am doing........? l am encoding the film as l write this and won't know until tomorrow if l have make a mess of it. l will need to buy a dvd re-writer soon which as you know are not cheap! so l would really like to have the confidence that l am as least going in the right direction with this! P.s l have Nero is this good enough also to burn with or should l be using a different burn program? any reply or help would be greatly appreciated.....'' thank you.![]()
Results 1 to 1 of 1
Gamma encoding for PAL DVD
By absence in forum Video ConversionReplies: 0Last Post: 9th Jun 2009, 08:53 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Advice Request regarding TMPGEnc, File encoding, and DVD creation w/ Menus
By Hal05154 in forum Newbie / General discussionsReplies: 9Last Post: 25th Sep 2007, 13:13 -
Encoding DVD to play NTSC given original footage shot on PAL
By ivo in forum Authoring (DVD)Replies: 7Last Post: 15th May 2007, 09:10 -
PAL HDV encoding DVD to play on all DVD/TV standards
By ivo in forum MacReplies: 7Last Post: 11th May 2007, 20:26
