Hello All
When I try to encode avi files into mpeg-1 it all goes well until it reaches 99% then I get a program error. Does anyone know why this happens or what I can do to remedy it?
I have adjusted the (Direct Show Multimedia reader) to priority 1 because it wasn't recognising the avi files to begin with, so I was wondering if that might have something to do with it?
Anyways, all help would be greatly appreciated. Take care ya all.
Results 1 to 9 of 9
I had a similar problem with an AVI where the audio was shorter then video.
I used SOURCE RANGE to cut the last portion of both and it worked.
Hope it helps.
Riccardom -
I had one that crashed at 95%.It turned out to be a bad avi.I redid the avi,and it worked fine in Tmpge
bmiller,ont.canada -
Don't worry about it, so long as you have all the conversion done. This happens quite a lot of times with lots of people. At 99% its fine, nothing much wrong with the source, maybe a glitch at the end.Originally Posted by Geohound
But if it happens at any other time (95%), there could be junk in the original, scan with Vdub for junk frames. -
Thank you all for your quick responses. I will try all the above.
Be well peeps. -
I think you should start a new post, your errors may not be the same.Originally Posted by winny22
However, load into Vdub and scan the AVI for junk frames, as I have mentioned above. Seach my posts for further info -
I don't mean to steal the post, but in Vdub, after you scan for bad frames, what then? I don't know how to remove them, or even locate them for that matter? Can't find any guides. It's frustrating after 60% encoding to find this out. Especially when I'm doing a frameserve from Vdub (pretty slow).
Thanx!!!!!! -
You don’t do anything with them !
After the scan, Vdub now knows where the bad frames are, so if you save out another copy using streaming, it will save the AVI "Without the bad frames"
Video > direct stream copy
Audio > direct stream copy
SAVE AVI (Movie 2.AVI) This saves without the junk frames it found.
You could use the old "Vdub MP3" (see my posts) to scan, and delete them manually if you wanted to, or at times with the new Version wont scan.
GOTSent deleting files upon completion
By draco_nite in forum Video ConversionReplies: 1Last Post: 2nd Nov 2010, 11:16 -
Video crashes all the time
By manicradio in forum Software PlayingReplies: 4Last Post: 9th Oct 2010, 23:38 -
I-Tunes crashes every time I try to play something :(
By Akhet in forum ComputerReplies: 4Last Post: 8th Dec 2009, 18:59 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 10:03 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 20:47
