you know how you can play a freshly burned VCD (MPEG-1) on your pc to test it out and it plays and runs ok on media player or any other player. How about on a SVCD (MPEG-2) what codec do I need to play it on my pc? I thought I had all codecs installed on my pc, but I guess not since I keep getting an error when trying to play an SVCD to test it out...
Here are my current codecs I have installed on my pc:
DivX 3.11 Alpha
DivX 4.12
DivX 5.0.2
MPEG-4 V1/2/3 VKI
Any suggestions, a link to the codec I need? Or is this not possible...![]()
later,
alirio -
You would need a MPEG-II codec. If you have any DVD software available, install that. If not, you can try some of the free MPEG-II codecs under Tools on the left.
you know I feel like an idiot after placing my post because I was just under the tools section and read on the DVD software and the MPEG-2 codec available for download...
since I really don't want to buy WinDVD or PowerDVD after the 30-day trial, out of the freeware ones which one would you recommend?
Maximus DVD? since this one requires the mpeg-2 codec do you still think it would cause sync problems, like if I just played it with media player alone?
Sasami2k? or Videolan?later,
alirio -
Personally I find the free ones not as good, they play jerky or out of sync. PM me.
Webm Codec Advice Needed
By jg84 in forum Software PlayingReplies: 9Last Post: 20th Apr 2012, 20:10 -
Kodak Zi8 codec needed for Vegas Video 8
By beammeup in forum Portable VideoReplies: 5Last Post: 4th Dec 2010, 11:14 -
Codec needed for particular .MOV file
By 6079 in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2010, 13:45 -
Needed : A adpcm audio codec link plssssss x
By xJensbigproblemx in forum AudioReplies: 3Last Post: 30th Jun 2010, 01:41 -
strange codec needed
By bountylord in forum Software PlayingReplies: 1Last Post: 8th Mar 2008, 11:40
