If I take a movie file that is the regular 4:3 ratio,can I change it to output a 16:9 ratio?
Can I also choose what 16:9 ratio I want?Like 1.85.1 or 2.35.1 anamorphic or non-anamorphic?
I have a movie file that I would like to change since I have a widescreen TV.
If any other programs are needed,please list![]()
I have TMPGEnc and VirtualDub and Panasonic MPEG1 encoder.
Thanks in advance.
just out of interest.. why would you want to do that? you aren't going to be able to see more on the screen, you'll see less because you've chopped off the top and bottom.
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Well see I didn't know that.
But instead of chopping off top and bottom,isn't there a way to stretch the image on the sides?Or would this distort the image?
I'm new to all this so I don't know what settings do what.
Thanks for the reply and info though. -
Yes it will distort the image, people will look short and fat. Your best choice is to just keep the 4:3 ratio and use one of the TV's picture mode to stretch it. On the 16:9 HDTV widescreen Toshiba TV I watch on, there's a mode that will stretch a 4:3 picture non symetically. Basically it stretchs the sides of the picture more then the middle. Since the important parts usually happen in the middle of the screen things don't look as distorted.
-LeeBear -
i've whipped up a few examples, XP maniac, just to clarify everything..
above, your original 4:3 image
above, the same image, with borders added to top and bottom, masking part of the image
above, the original image, squashed so borders can be added to top and bottom
so as you can see, changing the aspect ratio isn't really worth it!
the only instance where this may be useful is, for example, if a disc has been encoded incorrectly, you can crop part of it etc (i think this was the case with the attack of the clones bootleg that was around earlier this year.. the original bootleg was in widescreen, but the aspect ratio was wrong so the picture appeared stretched. somebody re-encoded the film in the correct ratio).
MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free
Changing aspect ratio on an mkv?
By vato76 in forum Newbie / General discussionsReplies: 15Last Post: 14th May 2011, 10:11 -
MP4Box - changing the aspect ratio?
By emilroh in forum EditingReplies: 2Last Post: 3rd Nov 2010, 08:41 -
Changing aspect ratio for WMV?
By vato76 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2010, 09:27 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 12:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 05:40
