Hi
I have downloaded a 700mb movie that i am really pleased with the quality,
but when i go to convert it with TMPGENC, it only can do 0-330 video bit rate, which makes the video quality Very bad and blocky.
i have tried loads of encoders but i have been told that TMPGENC is the bets one.
Please can someone help me as, on my pc the movie is brilliant quality but wen i try to convert it the quality is rubbish.
Please can anyone help me on my problem??
Matt
split your avi in two with v-dub. Open tmpgnc and unlock the template then up your bitrate to around 1800 to 2100 depending on size of movie. Burn on two cdr's.
kjmacke's suggestion is a good one....but I suggest you do a batch encode with TMPGE and using the source range split in two.
(splitting the avi/divx can sometimes lead to problems when encoding seperately)"Today is only yesterdays tomorrow" -
I seem to have found a better way. I dont understand why this works, but it seems to work most of the time when this happens. Instead of splitting it in two, just set the start and end frames. Just 'move to end frame' and set it there. With the last three movies Ive encoded, I've found this works. I was able to encode at over 800 instead of 220!
Perfect video on my 25" tv. -
Originally Posted by onetrueday
thats what source range does."Today is only yesterdays tomorrow"
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
how good quality is...
By Cazz in forum AudioReplies: 2Last Post: 23rd Jul 2009, 09:23 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 01:21 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59
